Adding subtotal in VBA
Dee
Hi all,
i have big list of 100 rows and 20 columns data for which i need to add sub total for each change in levels.
For Ex: Level 1 is broad category which have many Level 2's and Level 5's
Each level 2 is again have sub categories like 3's and 4's.
under each Level 2 we may or may not get level 3 or level 4. So the sum of Level 2 should be sub total of Level 3 & level 4 .Hope i am clear in my requirement.
Let me know if you need clarification...Your help in this is very much appreciated
Thanking you in advance
Dee
SL NO. LEVEL Total Cost
2 1 SUM(I4,I13,I15,I24)
3
4 2 SUM(I8,I11)
5 3 0.07
6 3 0.2
7 3 0.2
8 Subtotal of 3's SUM(I5:I7)
9 4 0.15
10 4 0
11 Subtotal of 4's SUM(I9:I10)
12
13 2 0
14
15 2 0
16 3 4
17 3 0.07
18 3 0.2
19 Subtotal of 3's SUM(I16:I18)
20 4 0.2
21 4 0.15
22 4 0
23 Subtotal of 4's SUM(I20:I22)
24 2 0
25 3 0
26 Subtotal of 3's 0
Have you tried the Sub_total command
goto Data, Sub-Total
follow prompts
Hi Hui,
Thanks for the reply...
Can't consider the subtotal of data toolbar as i am adding the rows and many formulas via macros...
Dee,
You can put the Subtotal's in via macro. Here's an example bit of code:
Selection.Subtotal GroupBy:=1, Function:=xlSum, TotalList:=Array(3), _
Replace:=True, PageBreaks:=False, SummaryBelowData:=True
check out the VB help file on Subtotal as it applies to a range for more detail.
