Adding Expiration Date and Days Left to Expire Problem
Newmord
I am new in VBA, please help.
I am using a workbook with set expire date. which runs behind userform at initiation
I have a workbook with userform which runs the workbook behind the userform when initializing.
I am tying to to add expiration date and days left for expiration to the workbook with this code:
Private Sub Workbook_Open()
    Application.Visible = False
    LoginForm.Show
    Dim exdate As Date
    exdate = Format("10/12/2018", "DD/MM/YYYY")
    If Date > exdate Then
MsgBox "Sorry! Evaluation period of the utility has expired." & vbCrLf & _
            "Please consult the Administrator.", vbCritical, "Outdated/Expired Version"
    mbox = Application.InputBox("Pls enter the password/code to continue...", "Password")
        If mbox <> "ABC" Then
    MsgBox ("You have " & exdate - Date & "Days left")
    Application.Visible = True
My problems are;
1. When the expiration date is not due message box appears already but it still terminates the application.
2. When I turn off the Application.Visible = False under the mbox <> "ABC" Then, then the application will not terminate even if the password is false.
Attached is the sample file
Login details to the attached file
USERNAME: user
PASSWORD: 1234
EXPIRED PASSWORD: ABC
Any help please?
  • REPORT.xlsm
It's misinterpreting your exdate. Try feeding as a serial with day, month, year explicitly called out.
exdate = DateSerial(2018, 12, 10)
Overall, you might change to this
    Dim exDate As Date
    Dim mBox As String
    LoginForm.Show
    exDate = DateSerial(2018, 12, 10)
    If Date > exDate Then
        ThisWorkbook.Close savechanges:=False
PassInput:
    mBox = ""
    mBox = Application.InputBox("Pls enter the password/code to continue...", "Password")
    If mBox = "" Then
        'User aborted, close
    ElseIf mBox = "ABC" Then
        MsgBox ("You have " & exDate - Date & "Days left")
        MsgBox "Invalid password. Please try again"
        GoTo PassInput
Can I have a way to stop the counter if the System Clock is backdated to earlier date?
Thanks in advance
Pls check it and fell free ask if any issue occurred.
To check it without manually changing system date just remove Int from here Int(FileDateTime(Me.FullName))
Dim exdate As Date, mbox As String
'Choose anyone as per need!
'Close the file if current date is behind last excel saved.
    If Date < Int(FileDateTime(Me.FullName)) Then
        MsgBox "System Date has been changed!", vbCritical, "Access Denied"
          ' .Close 0 'option one
          GoTo Alert ' option two/ choose where to go after it
ExCheck:
    exdate = DateSerial(2018, 12, 4)
        GoTo Login
PassInput:
    mbox = ""
    If mbox = "" Then
      Me.Close savechanges:=False
    ElseIf mbox = "ABC" Then
        MsgBox "Invalid password. Please try again.", vbCritical, "Error"
        GoTo PassInput
Login:
    LoginForm.Show
Alert:
MsgBox "You have " & CStr(Application.Max(0, exdate - Date)) & " Days left.", vbInformation
