skyh3ck
Hello guys
i have a data base where i want to first find the column header, 2nd in same column find a certain date, and 3rd return correponding date from same row 1st column.
So i have prepared one sample excel file
Sheet one - Calc - where user can enter the class and dates
Sheet two - Log - this log is where the data feeded each month regularly this is the file from where i have to retrieve the date
This is sheet one - where user will update the class and date of file, i want result from another sheet log where i have data feeded
This is the second sheet or tab where data is feeded - so whatever class is selected, the formula should first go in that column and check when the date of file crossed, and give me the date of current for that particular date of file. However one catch - some time in some case, date of file can go back, as marked in red, in that case any previous available date gets ignore, unless new date of file is not crossed in same column.
