Vlookup using excel VBA
JAMIR
Hello Respected Excel Ninja & My Dear Friends,
I have attached Sample workbook. I need vlookup using excel VBA. I'll just enter Vehicle No in Record Register and data should be fill in that columns.
Thanks & Warm Regards
Zameer
  • SAMPLE.xlsb
Why VBA?
That could easily be done with Formulae
Hello Sir,
I can done it by formulue. The vehicle number related other data is may vary sometimes. So i want to preserve all the record by this VBA.
ex: MH15AK8001 Depot is PANCHAVATI right now. So it will return Panchvati. But suppose if i Change it to Nashik-1 tommorrow then i can see the vehicle is transferred to Nashik-1 from Panchvati.
Thanks & Regards,
Zameer
Just use advanced filter. Plenty of examples out there. And copy paste to another sheet to preserve it if you need.
Hello Sir,
Here i attached sample file. I need to take daily entry of vehicle that's y i want VBA.
Or please tell me what wrong with that...
Zameer
  • SAMPLE.xlsb
Nothing wrong with using VBA. Just google advanced filter vba and you will find plenty of examples out there.
Hello Chihiro,
Thanks for suggetion, i want retrive data after enter the value in cell.
The will not touch once enter value.
Zameer
  • SAMPLE (5).xlsb
Hi Chihiro,
Thanks for your reply. That is what i want..
Sir, it is possible instead of enter vehicle no in Control sheet, i put vehicle number in column D to for extract record. It is depends on Cell enter event.
Thanks & Regards,
Zameer
