UDF for MID for "-" string & some criterias
Bhawani
Hi All,
I am unable to search out a for creating a UDF in attached file with below criteria :
  1. if "-" count =1 in cell range then output should be cell value as it is
  2. if "-" count >=2 in cell range then mid between first two "-"
  3. if value in cell range contains "--" (double minus sign consecutively) then output should be wrong entry
  4. if value in cell range does not contain "-" then UDF should give check entry
I have given a try but unable to reach result. please help me out.
  • UDF Trial.xlsm
Here you go.
Function MIDPART(myString As String, Optional mySym As String) As String
Dim symCount As Long
Dim newStr As String
'mySym = what to look for
'Defaults to a dash if not specified
If mySym = "" Then mySym = "-"
symCount = Len(myString) - Len(Replace(myString, mySym, ""))
Select Case symCount
    Case 0
        MIDPART = "check entry"
    Case 1
        MIDPART = myString
    Case Else
        newStr = Trim(Mid(Replace(myString, mySym, WorksheetFunction.Rept(" ", 999)), 999, 999))
        If newStr = "" Then
            MIDPART = "wrong entry"
            MIDPART = newStr
End Select
End Function
Thanks Luke, You make my night for sleep now it was not actually letting me sleep. Perhaps one thing i have noticed in UDF that your first if condition is not closed with End If see below :
please make me clear so that i could go 4 sweet dreams;):DD
Hi Bhawani ,
An IF statement requires a closing ENDIF only if it is over more than one line.
The following 2 pieces of code are absolutely equivalent :
Public Sub OneIf()
           num = 4
           If (num Mod 2) = 0 Then MsgBox "The number is even" Else MsgBox "The number is odd"
           num = 5
Public Sub AnotherIf()
           num = 4
           num = 5
Thanks Narayan,
Now its clear for me
end if is not require when we pass if condition with in line.
Why use a UDF and not an excel formula like
=IF(IFERROR(FIND("--",K8),0)<>0,"wrong entry",IF(IFERROR(FIND("-",K8),0)=0,"check entry",IF(IFERROR(SEARCH("-",MID(K8,SEARCH("-",K8)+1,LEN(K8)-SEARCH("-",K8)+1)),0)=0,K8,MID(K8,SEARCH("-",K8)+1,SEARCH("-",MID(K8,SEARCH("-",K8)+1,LEN(K8)-SEARCH("-",K8)))-1))))
@ Jake collins - because it will save my time and mind both.
simply it will take more time to type excel funcation with these manu funcations and also i was using same function you told me.
so just to get rid of repeatative function typing:DD:DD:DD:DD:DD
