Sir, right now its ok but not with added prefix (CID/COD..) have u applied table... how about if i need to extract any other data within same workbook.. should i use the same concept (for numbers / alphabets / both)
thanx for you time
Can you specify what will be the input ? Will it be only the number portion , or will it be both the alpha and the numeric portions , or can it be both i.e. sometimes you will enter the number portion alone , and sometimes you will enter both the alpha and the numeric portion ?
Using the Table feature makes formulae that much simpler ; since the table is dynamic , there is no need to use dynamic named ranges , since a reference such as Table1[ID] will automatically expand to include added rows.
I strongly recommend that since the feature is available , you should start making use of it.
To:Somendra Misra, Sir it worked fine for given i/p ....(jokingly) are u using any book or u connected to super computers such big formula....!!
Q: what is this "*" "$" (in excel) and how it works (just curiosity to know) other wise no problem sir...
Neither I use any book, nor my computer is Super Computer , The size of formula become bigger because I thought You want in the format that you mention in your file, like Col:C & Row 4.
Getting address is not big, extracting A,B,C i.e. column name and row number make the formula bigger.
May be somebody can cut short it. Personally I like huge formulas (if they don't hamper my over all speed as there will be lot of functions involved in them)
Than "*" is a wildcard character for any number of character, where as "?" is a wild card character for single character.
Than the return of ADDRESS function I am selecting as absolute, so it will return like $A$1 so $ is that.
To:Somendra Misra, Sir fine thankyou for valuable time... but still is there any book on excel for data referencing.... bcoz such small yet important things we dont know...
Well I don't know if there is any particular book related to data referencing alone. Many a times it's usage of Excel formulas only. Try referring to Excel help and go through the problems here posted on the forum. You can also visit chandoo main site to understand various formulas with a wide range of examples.
