Multi Criteria Index/Match Function w Partial Search
HKM
Hi
I am trying to write an index-match function with a partial text match.
Here is the formula that I have so far,
{=INDEX($A$5:$A$8, MATCH(1, ("*"&B13&"*"=$A$5:$A$8)*(C13=$B$5:$B$8), 0))}
Is there any way to make this work?
Thank you!
  • Multi Criteria Index-Match.xlsx
Hi
please see the attached
hope you like it
regards
  • Like
Reactions: HKM
Check out this approach.
Villalobos, thank you! This is awesome! Would it be possible to request a brief explanation of your function? Just so I can replicate it in the future.
Also, how would i go about adding additional criteria to this?
Hi
hope you like it
regards
Mohadin, Thank you for your response. I see that the function isn't giving an error anymore. However, it is returning the wrong value. It should return B7. Any ideas?
Hi HKM,
Another option:
=LOOKUP(2,1/(SEARCH(C13,B5:B8)*(C5:C8=D13)),B5:B8)
Thanks Khalid!
When I try to add another search criteria in the function, I get an error:
=LOOKUP(2,1/(SEARCH(C13,B5:B8)*(E13,B5:B8)*(C5:C8=D13)),B5:B8)
I need to match multiple criteria against a large file of text strings.
Thank you.
Hi KHM
you'd better do this as I understand
LOOKUP(2,1/(SEARCH(C13,B5:B8)*SEARCH(E13,B5:B8)*(C5:C8=D13)),B5:B8)
Maybe,
=LOOKUP(2,1/((C5:C8=D13)*MMULT(ISNUMBER(SEARCH(B13:C13,B5:B8))+0,{1;1})),B5:B8)
Remark : criteria in B13,C13 and D13 as per post# 1 indicated.
Bosco
