mithelesh
Hi all,
I have a code to split the data in to seperate sheets and paste in it.
follow as:
clik on split button.
select the data range.
and then mention for eg: 400
but can someone explain me the code.
what is inputbox do
what is workrng/parent
what does workrng.rows(1) do
Sub SplitData()
Dim WorkRng As Range
Dim xRow As Range
Dim SplitRow As Integer
Dim xWs As Worksheet
xTitleId = "User Defined Range"
Set WorkRng = Application.Selection
Set WorkRng = Application.InputBox("Range", xTitleId, WorkRng.Address, Type:=8)
SplitRow = Application.InputBox("Split Row Num", xTitleId, 5, Type:=1)
Set xWs = WorkRng.Parent
Set xRow = WorkRng.Rows(1)
For i = 1 To WorkRng.Rows.Count Step SplitRow
resizeCount = SplitRow
If (WorkRng.Rows.Count - xRow.Row + 1) < SplitRow Then resizeCount = WorkRng.Rows.Count - xRow.Row + 1
xRow.Resize(resizeCount).Copy
Application.Worksheets.Add after:=Application.Worksheets(Application.Worksheets.Count)
Application.ActiveSheet.Range("A2").PasteSpecial
Set xRow = xRow.Offset(SplitRow)
also please find the attachment.
follow as:
what is inputbox do
Sub SplitData()
Dim xRow As Range
