Villalobos
I use the following code to attach a screenshot about the part of worksheet into the email body and it is working perfectly. But if I protect the worksheet and after I would like to send it then the code is stop in the "createJpg" session (With ThisWorkbook.Worksheets("Dashboard").ChartObjects.Add(Plage.Left, Plage.Top, Plage.Width, Plage.Height).
Do you have any idea how is it possible attach to email body a part of protected worksheet as screenshot?
Thanks in advance the advice!
Sub sendMail()
Dim appOutlook As Variant
Dim olMailItem As Variant
Dim Message As Variant
Dim olByValue As Variant
If Application.UserName = "x, y" Then
If MsgBox("Would you like to send to recipients?", vbYesNo + vbQuestion, "Question for you") = vbYes Then
Application.Calculation = xlManual
With Application
.ScreenUpdating = False
.EnableEvents = False
Dim TempFilePath As String
Set appOutlook = CreateObject("outlook.application")
Set Message = appOutlook.CreateItem(olMailItem)
With Message
.Subject = "My project"
.HTMLBody = "<span LANG=EN>" _
& "<p class=style2><span LANG=EN><font FACE=Calibri SIZE=3>" _
& "Hello,<br ><br >You can see here the status. <br >"
Call createJpg("Dashboard", "A1:AA64", "DashboardFile")
TempFilePath = Environ$("temp") & "\"
.Attachments.Add TempFilePath & "DashboardFile.jpg", olByValue, 0
.HTMLBody = .HTMLBody & "<br><B>Daily report:</B><br>" _
& "<img src='cid:DashboardFile.jpg'" & "width='800' height='450'><br>" _
& "<br>All the best,</font></span>" & "<br ><br >" & "<br ><br >" & Application.UserName
.To = ""
.Cc = ""
.Send
.Display
With Application
.ScreenUpdating = True
.EnableEvents = True
MsgBox ("You do not have authorization, access denied! The file will be closed withing 5 seconds.")
Application.Wait (Time + TimeValue("00:00:05"))
ActiveWorkbook.Close savechanges:=False
Sub createJpg(Namesheet As String, nameRange As String, nameFile As String)
Dim Plage As Variant
ThisWorkbook.Activate
Worksheets("Dashboard").Activate
Set Plage = ThisWorkbook.Worksheets("Dashboard").Range("A1:AA64")
Plage.CopyPicture
.Activate
.Chart.Paste
.Chart.Export Environ$("temp") & "\" & nameFile & ".jpg", "JPG"
Worksheets("Dashboard").ChartObjects(Worksheets("Dashboard").ChartObjects.Count).Delete
Set Plage = Nothing
