Copying cells to a new sheet depending on cell value
Hi All,
Hope someone can help as this is driving me nuts. A bit beyond my limited excel skills.
I have created an order form where the customer can select the quantity of items from a drop down box next to the product descriptions. What i'd like to do is have a formula to copy the description cell, the item code cell and the cost cell, for the products the customer requires, onto another sheet to create a pro forma type invoice. I'm not at all experienced in VB but keen to learn.
Hope someone can help.
Thanks,
James
  • test sheet.xlsx
Hi James ,
From where is the product code to come ?
You mention both formula and VB ; you do not need any formulae if you intend to use VBA.
If you decide to use VBA , when do you want the data transfer to happen ? When the customer has completed an entire order , consisting of several items , or as and when the customer selects an item through the quantity dropdown ?
Just as you have a template for the menu , you should also have one for the invoice ; can you design one and put it in the workbook ?
After the data is transferred to the invoice tab , what happens ? Suppose the next customer is to again select from the menu ; what should happen to the previous invoice ?
The VBA coding is the last step.
Hi Narayan,
Thanks for the reply. I would like the transfer to happen each time a quantity is selected. I have added a basic layout of the pro forma which i will make prettier once i have the functionality.
In terms of multiple invoices it doesn't matter. Each order will be done on a separate excel file which will have the date as a reference. I have the product codes in hidden cells C and J.
Hope this makes things clearer.
Thanks,
James
  • test sheet 2.xlsx
