ONKAR BHOSALE
I have one problem while finding the closest possible match with certain value and I want value from adjacent cell should be executed on sheet.
For example I hav attached below sheet where i want GENERAL STORAGE VOLUME 160
should be checked in Jth column for nearest largest value and corresponding BIN name from C column should be executed.Data in column is not in ascending order so facing problems while solving this..I HAVE ATTACHED SHEET FOR THE SAME
s
s
