Sub Demo()
With Sheet1
With .[B3].CurrentRegion
If .Columns.Count = 1 Or .Rows.Count = 1 Then Beep: Exit Sub
N& = Application.CountA(.Offset(1, 1).Resize(.Rows.Count - 1, .Columns.Count - 1))
If N = 0 Then Beep: Exit Sub
VA = .Value
.Activate
ReDim TR(1 To N, 1 To 3)
For R& = 2 To UBound(VA)
For C& = 2 To UBound(VA, 2)
If VA(R, C) > "" Then
T& = T& + 1
TR(T, 1) = VA(R, 1)
TR(T, 2) = VA(1, C)
TR(T, 3) = VA(R, C)
With [A21]
.CurrentRegion.Clear
With .Offset(, 1).Resize(N, 3)
[B4].Copy: .Columns(1).PasteSpecial xlPasteFormats
[C3:C4].Copy: .Columns("B:C").PasteSpecial xlPasteFormats, Transpose:=True
.Value = TR
.Select
Welcome to Chandoo.org forums.
I have couple of questions for you.
1. How do you identify the table to process? Does it start from a specific cell e.g. B3 is top left cell in your example.
2. Where do you want to copy the results? To another sheet or just below your current data as you have shown?
a code demonstration upon post #1 sample workbook :Code:Sub Demo() With Sheet1 With .[B3].CurrentRegion If .Columns.Count = 1 Or .Rows.Count = 1 Then Beep: Exit Sub N& = Application.CountA(.Offset(1, 1).Resize(.Rows.Count - 1, .Columns.Count - 1)) If N = 0 Then Beep: Exit Sub VA = .Value End With .Activate End With Application.ScreenUpdating = False ReDim TR(1 To N, 1 To 3) For R& = 2 To UBound(VA) For C& = 2 To UBound(VA, 2) If VA(R, C) > "" Then T& = T& + 1 TR(T, 1) = VA(R, 1) TR(T, 2) = VA(1, C) TR(T, 3) = VA(R, C) End If Next Next With [A21] .CurrentRegion.Clear With .Offset(, 1).Resize(N, 3) [B4].Copy: .Columns(1).PasteSpecial xlPasteFormats [C3:C4].Copy: .Columns("B:C").PasteSpecial xlPasteFormats, Transpose:=True Application.CutCopyMode = False .Value = TR End With .Select End With End Sub
Another way to look at it! Thanks Somendra I will be able to use this in other applications as well - This forum is awesomeHi,
See the file, for formula solutions, (I assume you want to transpose Table 1 to Table 2), note I had inserted a helper column A next to table 1. Then created some named range, refer them in name manager. The solution is in the range G21:I36.
Public Sub TransposeData()
Dim rStart As Range
Dim lngLastRow As Long, lngLastCol As Long, lngFillRow As Long
Dim wsDest As Worksheet
Set rStart = Range("B2")
lngLastRow = Cells(Rows.Count, rStart.Column).End(xlUp).Row
lngLastCol = Cells(rStart.Row, Columns.Count).End(xlToLeft).Column
Set wsDest = Sheets("ORDER")
If wsDest Is Nothing Then
Set wsDest = ThisWorkbook.Sheets.Add(After:=Sheets(ThisWorkbook.Sheets.Count))
wsDest.Name = "ORDER"
wsDest.UsedRange.EntireRow.Delete
On Error GoTo 0
For i = rStart.Row + 1 To lngLastRow
For j = rStart.Column + 1 To lngLastCol
If Len(Cells(i, j).Value) > 0 Then
lngFillRow = wsDest.Cells(Rows.Count, rStart.Column).End(xlUp).Row + 1
wsDest.Cells(lngFillRow, rStart.Column).Value = Cells(i, rStart.Column).Value
wsDest.Cells(lngFillRow, rStart.Column + 1).Value = Cells(rStart.Row, j).Value
wsDest.Cells(lngFillRow, rStart.Column + 2).Value = Cells(i, j).Value
Next j
OK. Here's a code which should work for you.
Code:Public Sub TransposeData() Dim rStart As Range Dim lngLastRow As Long, lngLastCol As Long, lngFillRow As Long Dim wsDest As Worksheet Set rStart = Range("B2") lngLastRow = Cells(Rows.Count, rStart.Column).End(xlUp).Row lngLastCol = Cells(rStart.Row, Columns.Count).End(xlToLeft).Column Application.ScreenUpdating = False On Error Resume Next Set wsDest = Sheets("ORDER") If wsDest Is Nothing Then Set wsDest = ThisWorkbook.Sheets.Add(After:=Sheets(ThisWorkbook.Sheets.Count)) wsDest.Name = "ORDER" Else wsDest.UsedRange.EntireRow.Delete End If On Error GoTo 0 For i = rStart.Row + 1 To lngLastRow For j = rStart.Column + 1 To lngLastCol If Len(Cells(i, j).Value) > 0 Then lngFillRow = wsDest.Cells(Rows.Count, rStart.Column).End(xlUp).Row + 1 wsDest.Cells(lngFillRow, rStart.Column).Value = Cells(i, rStart.Column).Value wsDest.Cells(lngFillRow, rStart.Column + 1).Value = Cells(rStart.Row, j).Value wsDest.Cells(lngFillRow, rStart.Column + 2).Value = Cells(i, j).Value End If Next j Next i Application.ScreenUpdating = True End Sub
If Cells(i, j).Font.Color = 255 Then 'Change this color number to suit
wsDest.Cells(lngFillRow, rStart.Column + 2).Font.Color = 255
Modify the following block:
to:Code:If Len(Cells(i, j).Value) > 0 Then lngFillRow = wsDest.Cells(Rows.Count, rStart.Column).End(xlUp).Row + 1 wsDest.Cells(lngFillRow, rStart.Column).Value = Cells(i, rStart.Column).Value wsDest.Cells(lngFillRow, rStart.Column + 1).Value = Cells(rStart.Row, j).Value wsDest.Cells(lngFillRow, rStart.Column + 2).Value = Cells(i, j).Value
Code:If Len(Cells(i, j).Value) > 0 Then lngFillRow = wsDest.Cells(Rows.Count, rStart.Column).End(xlUp).Row + 1 wsDest.Cells(lngFillRow, rStart.Column).Value = Cells(i, rStart.Column).Value wsDest.Cells(lngFillRow, rStart.Column + 1).Value = Cells(rStart.Row, j).Value wsDest.Cells(lngFillRow, rStart.Column + 2).Value = Cells(i, j).Value If Cells(i, j).Font.Color = 255 Then 'Change this color number to suit wsDest.Cells(lngFillRow, rStart.Column + 2).Font.Color = 255 End If
Note: Do not forget to modify the color number that suits your case.
Sub DemoTransposeRed()
Dim AR(), Rg As Range
With Sheet4.[B3].CurrentRegion
For Each Rg In .Offset(1, 1).Resize(.Rows.Count - 1, .Columns.Count - 1)
If Rg.Font.ColorIndex = 3 And Rg.Value > "" Then
R& = R& + 1
ReDim Preserve AR(1 To 3, 1 To R)
AR(1, R) = .Cells(Rg.Row - 2, 1).Value
AR(2, R) = .Cells(1, Rg.Column - 1).Value
AR(3, R) = Rg.Value
If Evaluate("ISREF(ORDER!A1)") Then Worksheets("ORDER").UsedRange.Clear _
Else Worksheets.Add(, Sheet4).Name = "ORDER"
With Worksheets("ORDER")
.Cells(2).Resize(R, 3).Value = Application.Transpose(AR)
.Activate
