Filter based on string of numbers
mdfreeman
I am dreaming of being able to paste a string of numbers (separated by commas, semi colons or the pipe) into a standard filter.
My simple attempts haven't works. Is it possible? What is the correct deliminator?
Thank you in advance for the help.
Hi mdfreeman,
Just a thought- if you have a list of of numbers to be filter down than you can use advanced filter to get the data.
Thank you.
Interesting. I have never used this feature. Quick testing of isn't working but I will play more.
Thank you for taking the time to put the file together. Advanced filters makes perfect sense now.
Still, it would be nice to be able to drop multiple items into the simple filters
