mita parmar
Hi Chandoo,
Hope you are well.
I was wondering if you could help with a formula I need.
Basically, I need to write “simple” code which finds criteria 1, and then looks to find criteria b from the value ranges to give me the resulting factor value
Hope I have explained myself correctly and that you can help
Hope you are well.
