Engineering charts - too much data, i can't graph, HELP!
I am trying to scatter plot measurements of angles, I have 360 degrees listed on the columns and I have 243,000 measurements, each measurement is placed depending on the degree it falls, however, because of this amount of data, I can't graph more tan 255 columns or rows. does anyone know how I can do this?
Greg
How do you want that plotted ?
I assume Column A keeps going well above Z1000
What is the relationship of the Column A (Zxx) to the data
Can you post a small picture or sketch showing how you want the data plotted
How about these:
See attached file:
The file contains a macro that converts the data to a single table of 3 Columns
I then added some math to work out the X&Y values and plotted
Enjoy
  • Sample points Hui.xlsm
You can add more circular axis if you want
Just use the existing ones as a guide
You can run the macro on your data and it will rearrange it for you
