i'll refer to point 1, 2, 3, and 4
I'd like a dot selector in point 1, to be added to point to, bit to expand ofver the j and k cell above the annul and monthly heading
Essentially if i select monthly, (if you look under point three, the yellow tabs fac slip 1 and fac slip 2 need to be effected)
so if you look at point 4, if i select monthly, then monthly must show, and if i select annual , then annual must show
