Create automatic mails including personal excel charts in email body
Erez Shani
I would like to ask your assistant in my complex problem,
I have raw data (say table/xml...) of sales data for different salesperson.
I would like to send a weekly email to each sales person containing a chart with his own personal sales in the following week.
How can i create (automatically) a different charts for each salesperson and automatically email it ?
I appreciate any kind of help you may provide.
Thanks Erez
Erezam@gmail.com
The below code will create a new outlookmail and attach the selected chart to it.
Still some more information required on to customize the code
1) what type of chart is required
2) what are the details the chart should reflect
Sub CopyAndPasteToMailBody()
  Set mailApp = CreateObject("Outlook.Application")
  Set mail = mailApp.CreateItem(olMailItem)
  mail.Display
  Set wEditor = mailApp.ActiveInspector.wordEditor
  ActiveChart.ChartArea.Copy
  wEditor.Application.Selection.Paste
Dear Stanish Kv,
Thanks for your answer.
I've attached the file again, this time with an example for the mail to Chris. (see Sheet "Chris Mail example").
The idea is that each recipient will receive a mail with its own data, according to one email template (the same as in "Chris Mail example" sheet).
  • database example with mail example.xlsx
This needs some workings to do which may take some time
The idea is as follows
1) From the database create a pivot with the "name" in rowsource and value
2) By double clicking the value against a name in pivot will create a new sheet with that particular name's details
3) with the active sheet create threee separate charts
4) create a an outlook mail and attach the charts and send to individuals
5)Creating a loop for above steps to repeat till the last name in the piviot
I would require some time to create a macro to achieve the above
Use the below Code
Note: Incase you want to test the code, change the line ".send" to ".Display" to avoid sending mails directly
Sub SendwithChart()
  Sheets("Data").Select
  ActiveSheet.Cells(1, 1).Select
  ActiveCell.CurrentRegion.Select
  srcdata = ActiveCell.CurrentRegion.Address
  ActiveWorkbook.PivotCaches.Add(SourceType:=xlDatabase, SourceData:= _
  srcdata).CreatePivotTable TableDestination:="", _
  TableName:="PivotTable1", DefaultVersion:=xlPivotTableVersion10
  ActiveSheet.PivotTableWizard TableDestination:=ActiveSheet.Cells(3, 1)
  ActiveSheet.Cells(3, 1).Select
  ActiveSheet.PivotTables("PivotTable1").AddDataField ActiveSheet.PivotTables( _
  "PivotTable1").PivotFields("name"), "Count of name", xlCount
  With ActiveSheet.PivotTables("PivotTable1").PivotFields("name")
  .Orientation = xlRowField
  .Position = 1
  .ColumnGrand = False
  .RowGrand = False
  ActiveSheet.Name = "Pivot"
  Sheets("Pivot").Select
  Range("B5").Select
  Do While ActiveCell.Value <> ""
  Selection.ShowDetail = True
  ActiveSheet.Name = Range("C2").Value
  Range("B:B,F:F").Select
  ActiveSheet.Shapes.AddChart.Select
  ActiveChart.ChartType = xlLineMarkersStacked
  ActiveChart.ApplyLayout (9)
  Range("B:B,G:G,I:I,K:K").Select
  ActiveChart.ChartType = xlColumnClustered
  ActiveChart.ApplyLayout (1)
  ActiveChart.ChartTitle.Text = "Sold"
  Range("B:B,H:H,J:J,L:L").Select
  ActiveChart.ChartTitle.Text = "Revenue"
  mail.display
  ActiveSheet.ChartObjects("Chart 1").Activate
  ActiveSheet.ChartObjects("Chart 2").Activate
  ActiveSheet.ChartObjects("Chart 3").Activate
  With mail
  .TO = ActiveSheet.Range("D2").Value
  .Subject = "Test"
  .send
  ActiveWindow.SelectedSheets.Delete
  Loop
