drewmiller
Using Excel 2010 on Windows XP Pro. I have my data (formatted as a table) in one file with my charts in another. Whenever I switch programs, look at another excel file, another worksheet, scroll to the bottom of the page (basically any action where I'm not looking directly at the chart), the chart disappears or only shows certain portions of it.
Example 1: I need to email a co-worker and switch over to outlook. When I return to my charts, they are gone, poof, vanished.
Example 2: The charts look great, but I need to format the chart area. The format chart area box appears, I make my change and click ok, then the charts only show the portion that was not covered by the format chart area box.
For any instance when they disappear, if I click anywhere where the chart is supposed to be, it will reappear in its correct form.
Appreciate any help!
-dm
-dm
