Sub ThisGuySeemsToBeLazierThanButObUtHc()
' constants
' access file type
Const ksDBPattern = "*.accdb"
' folder path
' \\zzz... full path
' x:\zzz... full path
' zzz... relative path
' "" actual path
Const ksPath = ""
' access table list
' x,zzzz[,zzzz]
Const ksTableList = "X,Table_1,Table_3"
Const ksSeparator = ","
' others
Const ksColon = ":"
Const ksBackSlash = "\"
Const ksDash = "-"
' declarations
Dim cn As ADODB.Connection, rsT As ADODB.Recordset, rs As ADODB.Recordset
Dim vTable As Variant
Dim sPath As String, sTable As String
Dim I As Long, J As Long, A As String
' start
' path
If InStr(ksPath, ksBackSlash & ksBackSlash) > 0 Or InStr(ksPath, ksColon) > 0 Then
' full
sPath = ksPath
' relative or actual
sPath = ThisWorkbook.Path
If Len(ksPath) > 0 Then sPath = sPath & Application.PathSeparator
sPath = sPath & ksPath
' tables
vTable = Split(ksTableList, ksSeparator)
' workbook
With ActiveWorkbook
' remove worksheets
For I = .Worksheets.Count To 2 Step -1
.Worksheets(I).Delete
Next I
' create worksheets
For I = 1 To UBound(vTable)
.Worksheets.Add , .Worksheets(I)
.Worksheets(I + 1).Name = vTable(I)
Next I
' process
A = Dir(sPath & ksDBPattern)
I = 0
Do Until A = ""
' new db
I = I + 1
' open db
Set cn = New ADODB.Connection
cn.Open "Provider=Microsoft.ACE.OLEDB.12.0;" & _
"Data Source=" & sPath & A & ";" & _
"Persist Security Info=False;"
' open rs tables
Set rsT = cn.OpenSchema(adSchemaTables, Array(Empty, Empty, Empty, "Table"))
Do While Not rsT.EOF
' table
sTable = rsT!TABLE_NAME
For J = 1 To UBound(vTable)
If sTable = CStr(vTable(J)) Then Exit For
Next J
If J <= UBound(vTable) Then
' open rs each table
Set rs = New ADODB.Recordset
rs.Open "select * from " & sTable, cn
' ws
With Worksheets(sTable)
' get titles, if 1st time
If [A1].Value = "" Then
For J = 0 To rs.Fields.Count - 1
.Cells(1, J + 1).Value = rs.Fields(J).Name
Next J
' get data
J = .[A1].End(xlDown).End(xlDown).End(xlUp).Row + 1
.Cells(J, 1).CopyFromRecordset rs
' close rs
rs.Close
rsT.MoveNext
Loop
' close rstables
rsT.Close
cn.Close
' cycle
A = Dir()
Loop
' end
Set rs = Nothing
Set rsT = Nothing
Set cn = Nothing
Beep
